STEP file has strange geometry
Hi everybody,
I have a very strange mistake now in my RH8/GH process.
  1. I generate geometry in GH with boolean and trim comands also.
  2. The geometry is exported as .step by GH (Pancake/Export As)
  3. When I import the geometry into RH8, the geometry has some serious mistakes.
left: GH bake | right: imported .step file
If i save the geometry as .3dm, everything is fine.
Do you have any advice?
All the best, Rupert
I am going to guess tolerance issues, but I cannot tell without the example. Can I get the original GH definition and then I can run it thru the process described?
If the model is saved as a #DM, then opened again and saved as a STEP file does it mess up again on import?
