Step-by-step tutorial on how to migrate UI
I’m not surprised that I failed at my attempts to recreate my home Rhino Beta UI on my computer at work.
I want it to look exactly the same, my containers, my popup, and toolbar placement.
Is there a step-by-step tutorial on how to do it?
Hi
Did you export your custom window layout and imported that on the other computer…?
WindowLayout. > Save Window layout > Manage widow layout > Export Window layout… :slight_smile:
then on the other computer: Import Window layout
HTH
Akash
Of course, I exported Window Layout and Toolbars, imported both and I had my Popup menu set up correctly but everything else just dissapeared. No panels, no command line. I had to configure everything from the scratch once again.
Hi -
Could you post that .rhw file here so that we can take a closer look at that one?
