Dear Karamba users,
I am trying to make a simple steel-concrete composite bridge. However, I have a problem with connecting my concrete deck slap to the shear studs on the longitudinal steel girders. I add small vertical pins between the beams and the deck and tried to connect these small pins to the concrete deck using the Joint-Agent component. Then I add a translational spring stiffness to mimic the stiffness of the shear connector. However this does not work, the agent-joint component has no influence on the displacement of the bridge.
Could somebody help me? Does anyone have any idea where it’s going wrong and what I can do to make it work?
Niels
Composite superstructure.gh (227.4 KB)
