Spoiled by SubD Reflection, Now Want it for Everything
I am using a birdsnest of curves for a ongoing approximation of a vehicle frame, for which I use Multipipe add diameter to check for clearances.
The problem is: now I want to just reflect half of curves, and have the other updated on the other side, just like the SubD reflect can do.
The transform Symmetry is supposed to do perhaps one, but it’s not the same. Somethings things may be scaled, which is pretty even from side to side.
mirror with history enabled will do this- it’s not quite the same as subd symmetry but will do what you are describing.
Pipe has history too-
