Splop not working as I would like
Can’t seem to get the object to align on the surface when using splop.
Feel free to direct me to another post I’m not finding if this has been a problem for someone else on here.
Thank you. The data is internalised.
testing gh.gh (31.7 KB)
Haven’t looked at your file yet. Try transposing the surface.
So you are getting the plane from just one of the Breps Leopold? That was the issue?
Yes, because all surfaces are built on the same plane.
What am I missing?
Had to do this for some reason?
I attach corrected file.
testing a gh.gh (40.1 KB)
Weird, Still get this when I open the one you made. Don’t know wheat I’m missing.:
It may depend on the version of Grasshopper.(March 17, 2025)
Attach your definition.
This works fine in Rhino 9 WIP.
Considering I got around the problem by deriving the plane input via Surface evaluation I don’t think I’ll bother troubleshooting anymore if it’s a version of grasshopper problem.
I have no problems with Rhino 8 either.
I removed Pufferfish and added the yellow group to get the Splop ‘P’ (Source Plane) input.
Splop_2025Mar20a.gh (38.4 KB)
Not sure this is a bug?
P.S. In the yellow group (version ‘b’ below), replaced Planar (curve test) with Is Planar (surface test), so both versions of Boundary now work.
Splop_2025Mar20b.gh (35.8 KB)
Worked very well, thank you Joseph.
