Challenge,
There is a list with text items.
I would like to split (and only split) at the location where ‘CX’ are directly behind each other.
So not at only the ‘C’ or ‘X’. I tested (CX){CX}‘CX’ but didn’t work.
Thank you once again :).
But I just came to the concluion there is still 1 challenge to go:
Because I would like to split the items on ‘multiple’ character combinations as shown below.
Unfortunately it is only testing the first character combination to the first item , and the second combi to the second item, instead of testing all the items against the 3 possible chracter comninations.
More or less I have a similar problem - seems fairly simple problem, but I can not get to the bottom of it:
I have a huge .txt file with multiple thousands of data rows (both numbers and letters). The data is repeated in cycles of different lengths. I want to divide the data into branches based on first line of each cycle.! What could be the solution?
