Split text based on character, but keep 'splitting character'
What about this:
  • replace your splitting character with another uncommon symbol + your character
  • split your text by using the uncommon symbol
For example:
“The quick@ brown fox jum@ps over the lazy dog”
Replace “@” with “%@”
now you have
“The quick%@ brown fox jum%@ps over the lazy dog”
now split by using “%”
The quick
@ brown fox jum
text split keeping splitters.gh (12.1 KB)
(The null checking and stream filter is for when you have a single text string input at start…)
Yes, that is a much simpler solution. :+1:
-Kevin
Hi Kevin,
I got one more challenge to go. :slight_smile:
Would it be possible to modify the script in such a way, that the ‘original Path’ is also present in the end result?
e.g. example below:
2023-02-11 Split text and keep splitting character + tree structure.gh (12.6 KB)
Many thanks :slight_smile:
I prefer using C# over Python for manipulating DataTrees.
Here’s how I would do this (slight modification to the C# component I posted before):
Edit: add grasshopper file :man_facepalming:
2023-02-11+Split_txt_keep_splitters+tree_paths_re.gh (12.6 KB)
-Kevin
Find missing numbers in the data.
This is currently in the initial stage. How do I remove some unwanted or incomplete data? How do I remove the number and date?
find miss number.gh (10.1 KB)
