I’m using the split command to cut a surface by a NURBS closed contour:
and instead of having 2 surfaces, I get 4 surfaces which partially don’t fit the cutting curve:
However if I use the command SimplifyCrv beforehand on the cutting curve, I get the expected result:
Additionally,
I’ve tested with multiple tolerances, the result is the same.
The behavior is the same using Brep.Split() in Python.
It happens on Rhino 8, but not Rhino 7.
Can you post the file with the closed curve and the surface?
Strange. If the splitting curve/polyline is split and then joined back together the surface splits normally.
How was the splitting curve/polyline created.
menno
(Menno Deij - van Rijswijk)
February 28, 2025, 1:48pm
5
Yeah, that’s not supposed to happen. I’ve logged the issue here .
The difference before and after explode+join is that before it is a degree-1 nurbs curve, while after it is a polyline. Of course that shouldn’t make any difference, but it does.
It has been created using python rs.AddNurbsCurve with all the control points, knots,…
Same for the surface.
