I have a problem with dendro volume difference. With the volume difference operation, I have splittet my original volume into two seperate, but entagled volumes. These two seperate volumes, are however still saved as one single dendro volume in the volume difference result. Now I am searching of a way to split these two volume halfes, to later completely get rid of one half. Does anyone know a way to do so?
Yes, that is exactly my problem. I am searching for a way to end up with two seperate volumes.
Maybe the volume difference operation is not the right one for this case, but i couldn`t think of any different option.
So either i need to find a different option to split a volume with another one, or I need two find a way to split the entangled, but not connected volume after the volume difference operation into two seperate ones.
Unfortunately there isn’t a “Disjoin Volume” component in Dendro so the only option it to (a) rework the Boolean logic to output the separated volumes or (b) do a Volume to Mesh out, Disjoin Mesh, then back into Dendro.
The Mesh Disjoin option is computationally slow but, in cases like yours, might be the only option.
