I want to create a hole in this volume using another volume (the cilinder) using dendro or any other prompt that will work. I’ve tried the dendro difference and the intersection but it doesn’t create the hole.
When I try with Mesh Difference, it creates the hole, but the surface of the cilinder remains
And when I bake it, the volume it’s hallow
How can I create this hole in this volume?
porifera recuperado.3dm (354.3 KB)
porifera recuperado.gh (18.2 KB)
Here’s a way you could do this with Isopod
porifera recuperado2.gh (36.6 KB)
To use solid difference the solid (in your case the cylinder) has to be a solid brep first.
NB: Please do not include plugins when uploading to the forum. (unless it is a question about the plugin) and/or mention it. We do not have all plugins installed (or do not want to).
Regards, Eef
porifera recuperadoEW.gh (12.9 KB)
thank you so much, the hole is now working! Sorry for the plugin part, I totally forgot about it, I was using it to trim the main solid.
I used the path you showed but now I’m having trouble trimming the solid, when I do it gives me what’s on the outside of what I actually want, how can I fix this? I’ve tried SplitBrep and Solid Difference, this is the closest I could get, using TrimSolid.
porifera 2.3dm (83.2 KB)
porifera 2.gh (22.2 KB)
I will definetly check that out! But this is a project and I need to follow this methodology, but thank you so much for the tip
Good morning Luciana,
Multipipe creates SubD. To work on that, you have to (my words) turn it into Nurbs. This is done with Join Brep.
then 3x SDiff to get to the result.
porifera 2EW.gh (21.3 KB)
Good morning! Thank you so so much! You have a very good teaching style, thanks for help!
