I would like to subdivide the any complex shape into multiple rectangular shape. Kindly see the attached image where I highlight the rectangle above shape. Is there any plugin to divide? I tired multiple method but didn’t able to archive this.
Hello
it could be possible but it could be better if you give more information on the “complex shape”
Are the curves parallel ?
is there a tolerance ?
A min rectangle size ?
What to do with parts not transformed to rectangle ?
Thank you, but I tried these method’s as well, but it works only for shape which is at right angle but not for acute and obtuse angles. please refer the attached image.
• Yes, the curves always parallel.
• Straight lines and there are no minimum and maximum size it depends on the shape.
• Don’t consider the part not transformed to rectangle. Split shape into rectangle.3dm (304.3 KB) Split shape into rectangle.gh (17.3 KB)
Some logic must be added, depending on type of curve (linear), obtuse acute angle …
Then when rectangle are found, it will be also possible to join some of them.
Gilbert Tessellation will be on Nautilus plugin, but you find it is some discussions Split shape into rectangle.gh (16.1 KB)
Other logic could be implemented. For example find 2 consecutive right angle which mean that a rectangle could surely be found. Doing that with some recursion could help to cut the shapes. It requires time and/or money to develop this kind of tool.
