Spiral from point to point with non constant slope
Hi guys,
I know how to make a spiral using polar component. But what I am trying to make is to have
  1. Two points which I can move on a circle and these point will always be an end of spiral curve
  2. And spiral between these two points should have variable slope.
For second question I thought to use graph mapper
Hope images will help
CustomSpiral.gh (6.4 KB)
I’m not a Graph Mapper specialist but it can be used to do what you want.
In my case I used a python script to generate the spiral. I needed to divide the resulting curve and deconstruct the points to get the Z values of the points.
CustomSpiral.gh (20.8 KB)
Here is a similar method to Martin, but without creating the initial spiral:
CustomSpiral_V2.gh (10.6 KB)
Thank you guys,
@Adam_M I did something similar to yours but,
Not sure how to keep track of the angle between two points?
You see when I past 180 degrees it doesn’t work ?
CustomSpiral.gh (16.4 KB)
Basically how to fix this ? :slight_smile:
spiral
CustomSpiral.gh (15.8 KB)
Hi @Mahdiyar
Thank you. I made a wee progress on this.
I am trying to build a second spiral on top of the first one.
I was using the same principle but for some reason it is still misses the point (picture 1)
In the middle I do want the spiral to change its direction. (picture 2 is correct)
Thanks
CustomSpiral_01.gh (26.1 KB)
Like this?
CustomSpiral_01_v1.gh (30.6 KB)
Thank you @Adam_M
I solved it last night :slight_smile:
Hey Adam,
I still struggle to get the spiral look the way I want. Basically what ever I do two spiral curve are parallel :frowning:
I want to be able to control the amount of squashiness , see image below… red line it is what I want
CustomSpiral_03.gh (37.0 KB)
I’m not sure exactly what you are looking for, but maybe this could give you some ideas:
CustomSpiral_03_v2.gh (37.3 KB)
Thank you,
Will take a look over weekend.
Have a good weekend Adam, thanks for help
Well not exactly :slight_smile:
Two spiral curves have to start and end in opposite points :slight_smile:
@Adam_M , I thought about it and it looks like, I need
  1. Two spiral curves which start fro opposite points , this is done
  2. One of the curve has control of pitch or squishiness without actually increasing number of revolutions of the spiral.
So when I loft / rail between two curves profile appears squished at one side.
Hope my sketch will help.
Hi guys @Adam_M @martinsiegrist @Mahdiyar
Apologies for asking to many questions.
I made an experiment in rhino, to be able to get the shape I want I had to use mesh cage to deform curves.
Is there a way I can do the same with graph mapper or scale within Grasshopper ?
CustomSpiral.gh (24.0 KB)
Thank you @martinsiegrist
I will take a look now.
I was trying to do it with attracting points… to be able to have more control.
Not sure how to fix the curve at ground floor though :slight_smile:
It is difficult to help you without a file.
Sorry @martinsiegrist
See attached CustomSpiral_03.gh (55.1 KB)
I placed only one point for now, but I assume I can use multiple attraction points to control the curve. Almost the same way you did with graph mapper
Sorry can’t see the point because it’s not internalized.
