I am trying to constrain the lattice structure above. I have done the translational constraint by using symmetry planes. Now I need to specify the necessary rotational constraint. The difficulty is the vector of rotational constraint is different at each node location. I have managed to create vectors/planes for a limited number of nodes along the symmetry plane but it is time consuming. Is there an easier way of doing this.
Hi Matthew Thank you for the info. That works great.
Just tried as you suggested. However it appears that all the generated planes are being applied to each of the node within the selected set. I attach a copy of the definition.
SphericalConstraint.gh (105.2 KB)
Hi, this might be a small bug in the SupportAgent component
please use this workaround
SphericalConstraint-mt.gh (115.7 KB)
Thank you Matthew
