I use special texts a lot for drawings title blocks relating to DocumentText values. As I want to transfer these drawings to clients as DWG, the title blocks become also awful/useless.
Is there a trick to bypass this limitation?
Is it planned to add a feature (maybe coming versions), that store special texts values as “static” whenever text is exported?
I’ll add this to the list - I’m not sure how hard or easy that might be to fix - meantime it may be possible to temporarily convert ‘fX’ text to the evaluated text and then undo after exporting… I’ll see if I can figure out a way.
Thank you for your reply.
Out of curiosity, I tried again with v5, where it seems to work as expected: the fx-text evaluated value is exported instead of the %<…>% string.
