Hi Dears, Any help how to fix my definition to have option to sort the surface numbering?
sort by the panel centroids instead of the surface order, that usually fixes the scrambled numbering. for the top view in your screenshot, sorting by y first then x should give you rows running 1, 2, 3 across like you marked
Please share your file so someone can show you how this could be done.
Weight sorting.gh (9.9 KB)
try this changing the sider values
No, “mate”.
From this forum’s guidelines :
3. Attach minimal versions of all the relevant files
If you have a gh file you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from a gh file. You can use the Internalise Data menu option to cut everything to the left of a parameter:
Simplifying a Grasshopper network
If you are referencing curves or breps or meshes from Rhino, you can also internalise them so you won’t have to post a 3dm file as well as a gh file. If you’re unsure whether all the relevant data is internal to the gh file, try opening it in an empty Rhino. Does it work? Good. No? You’ll need to internalise more.
