Sort list using Gh Python Component
Hello Everyone,
I am trying to sort the list of numbers in ascending order. I have used the Sort list component of Grasshopper and I got the desired list but when I call this component using python it give me same result but with two list. One with the required list of numbers and second one with None. Any idea why is this happening?
Thanks in advance
Do you have the .gh?
yes.
sort_list.gh (7.4 KB)
I have missing sof_on import…this looks like a gpt chat generated entry?
I haven’t used chat gpt.
Use the native Python sort and make sure to cast your data to integers, else they will sort as strings:
sort_list_Anders.gh (12.5 KB)
import Grasshopper as gh
import ghpythonlib.components as ghc
dokument = ghenv.Component.OnPingDocument().Objects
D=[]
D_sort=[]
if Aktualisieren:
    for obj in dokument:
        if type(obj) is gh.Kernel.Special.GH_Panel:
            if obj.NickName=="LF":
                D.append(obj.UserText)
    D_sort=ghc.SortList(D)
    D_sort = D_sort.keys
            if obj.NickName==Panel_Name:
                obj.UserText='\r\n'.join(map(str,D_sort))
                obj.ExpireSolution(True)
Or you could just use Python sorting:
D=[]
if Aktualisieren:
                D.append(int(obj.UserText))
    D_sort = sorted(D)
                print D_sort
Thank you very much
