I wanna use boolean to modify a stl file,but it become mesh when I import in rhino
just like this
how can I do to modify it?
STL “are” meshes. If you don’t want meshes you should use a different file format.
Hello - - MeshBooleanUnion/Difference/Intersection are the commands to use but they are not all that robust - can you post the file?
because I only have the stl file but I need to modifiy it.
here are my rhino files, thanks very mush!!
my stl.3dm (191.7 KB)
Hello - the mesh is a block. ExplodeBlock and then use MeshBooleanUnion. You should make the small part fully intersect the mesh before the Union.
thanks!!! I’ll trying that!!
