Solving intersection of non-linear curves
I’m trying to find perpendicular intersection of curve that passes over lines. However, that curve is not coplanar with the lines. How can I find the points on the curve wherever it will intersect those lines if it was coplanar with them?
I tried various components but couldn’t figure out.
INTERSECTION OF NON-LINEAR CURVES.gh (11.9 KB)
INTERSECTION OF NON-LINEAR CURVES_re.gh (14.1 KB)
If you project the curve to the plane it will also map its parameterisation, so you can use the t-values on the original curve (if that’s what you need, not sure):
project.gh (7.3 KB)
John.
Curve Proximity (CrvProx), white group:
INTERSECTION OF NON-LINEAR CURVES_2020Sep4a.gh (6.8 KB)
Thanks. That’s exactly I was trying to do!
Thanks! This is quite simple solution :+1:
