I have a problem with a drawing of mine. I’m doing when I print to PDF the outlines of solids and surfaces are extremely thick. In the drawing area, when using my viewport everything looks fine, but whenever I print the lines get messed up. I tried changing the surface edge thickness in the Display Mode, tinkered around with the print settings, but with no success. Only option I found is to Make2D, but I’d prefer to print the 3D object.
See pictures (thin lines is in viewport):
Thank you
Gernot
