Dear All
I am doing two similar SDiff operations where one is doing well, but the other is not doing as I wish. Can anyone please help and spot the mistanke?
Kind regards
Mohammad
The grasshopper files is attached:
Question SDiff.gh (804.0 KB)
Dear All
Kind regards
Mohammad
This is almost a “common” problem in rhino too, not just grasshopper.
You have a lot of common/coincident edges between A and B, and you have also coincident surfaces, you should avoid doing that.
As in your case, sometime it works, sometime not (especially with curved nurbs), it’s not a reliable method.
You should make geometries that fully intersect, not that just “touch” in some point.
