Hi there,
Following on my previous post about a definition that makes input curves sketchy. Not really relevant to this post, but I’ve developed it a bit further; the previous version didn’t take the length of the input curve into consideration, which meant that on shorter curves you ended up with a more “scribbly” looking line. Screenshot below you can see that regardless of curve length they are all relatively uniform in appearance.
I now realise that my definition doesn’t work as intended when the input curves include both curvy and straight lines. Result below, showing that the curved line input gives a “dotted” line.
I have a separate definition for curvy lines that fixes the issue, but then doesn’t work for straight lines.
The only difference between the two definitions being this:
I’d like to have one definition that can accommdate both, but unsure how to achieve this. Any ideas?
FYI, anyone is welcome to use this definition in their own work, in fact I am quite keen to see what you come up with. I really enjoy this forum and the opportunities for learning it facilitates.
multiple sketchy lines.gh (16.0 KB)
