Simplify nurbs curve to arcs and lines
I need to convert (simplify) a nurbs curve and i use for this RhinoSimplifyCurve. Sometimes it works very good, but very often it simply does not convert the nurbs curve to arcs. In Rhino itself i can convert the nurbs curve with the command “_Convert”.
Is there a c++ function call available with the same functionality as “_Convert” ?
Hi @dsw,
I don’t think RhinoSimplifyCurve was ever designed to be functionally the same as the Convert command, albeit that the command does use this function.
Anyway, I’ve added a wish item for such a function.
https://mcneel.myjetbrains.com/youtrack/issue/RH-40254
For now, all I can suggest is scripting the command.
– Dale
