Hello everybody,
I’m trying to solve a gridshell structure, but I don’t seem to get an accettable output. Any idea on where I should change the script?
karamba_forum.gh (84.8 KB)
Hello everybody,
Hello parametricalb,
there seems to be a Karamba3D problem in the creation of the specific warning that your definition causes - it seems to be too long for Grasshopper to deal with it as one string.
You constrain all nodes (roughly 15000) to zero displacements. Is this on purpose?
Best,
Clemens
Hello Clemens, thank you for your reply.
I just found out I confused the external pin joints with the internal ones (the knots). Though they have the same reactions, the displacements are different in the two cases.
So I just used the Beam Joint Agent component.
