Hello anyone that can help me!
I am very very new to grasshopper and am trying to manipulate a defined pattern within a shape (chair back). It is going to be knit so it only has to be two dimensions.
Parameters:
– Base shape pattern is a 16x5mm shape
– 5mm row space and 5mm column space
– Row and Column space need to be constant
– As the pattern goes to the edges of chair back I want the main shapes to shrink horizontally and vertically
– i.e. as the pattern goes towards the top of the chair back the height of the main shape decreases
– i.e. as the pattern goes towards the sides of the chair back the width of the main shape decreases
– The change of the size of shape needs to be in increments of 1mm
I attached an image of the pattern on the chair back, the pattern itself, and then a visualization of this idea (note: the visualization is the incorrect pattern but is what i am going for, radiating out from the center)
Any and all help is appreciated on how to start this project, I am at a bit of a loss!
Thank you!
– Chris
