Shrink and Divide patch surface?
Hello !
I am trying to create a framework of a parametric surface which has been created with patch command.
However when i divide the surface it devides all the untrimmed surface. How can i divide only the trimmed surface?
Divide patch surface.gh (9.6 KB)
Thanks in advance!
You cant.
And if you want to understand why: Rhino - What are NURBS?
So there isn`t any solution in my case?
retrim the divisions with the input surfaces trim edges.
Ok thank you very much. Which command i have to use in order to trim a surface with another surface for example in grasshopper. I mean is there an equivalent command with rhino trim in grasshopper/
This could be one way…
Divide patch surface_re.gh (13.3 KB)
Thank you. However just out of curiosity is there any way to trim a surface with an extrusion in grasshopper. Cause I haven`t found a way yet.
