Shortest path between two sets of points
shortest path.3dm (94.7 KB) shortest path.gh (9.6 KB)
I was able to create lines between these two sets of points. However, I need each point to connect to the closest point from the second set of points.
If a point already has a connection, the link is created at the next point it is closest to. So every point has a different connection from the first set of points to the second set of points.
How can i do this?
You can use looping by anemone for instance.
shortest path_re.gh (14.2 KB)
Thank you for your reply. This is exactly what i wanted to achieve. However, the loop only works with the same number of points in each set. How do I go about this when the number of points in the second set of points is more than the number in the first?
Thank you! It was a small error I had made sorry
