Shell Result Analysis
Hi Clemens, thanks for the advice.
I supposed that point supports is not the best way for the stress singularities but I don’t think in this massive way.
The problem is that I cannot even choose a shear value and supposing it’s almost right, because there’s the same problem of higher value for high discretization mesh.
I will try with these short beam peaces and support some point along of them, but in this way I have to include these in the mesh and I cannot use the regular mesh, but the inclusion brep.
If, after this I have the same problem, what can I do to have a shear stress value in x and y? I can’t choose 3000 kN/m value because it’s not true as stress value for a model like this.
I just need an approximate value to impose verification on shell element.
Best,
Leonardo
Can anyone help me about my issue??
after long time of research about Karamba, really magic but actually it good at the supported input stage to optimize structure options, to complete project is so complicated, and still some risk, I hope Karamba is more completely in Future
love it.
Hi Clemens
karamba-1.gh (55.0 KB)
I have a problem when analyzing a mesh surface (floor) in Karamba3D. If I connect the surface element to Assemble Model and then Analyze Model, it gives an error and won’t work at all. But if I connect only beams and columns, it works fine.
I also tried the latest Analyze Shell model from the Karamba3D page, but none of them seem to work. Can you please check this issue?
Btw, I followed your lesson from:
Thanks!
Hi, there are no supports in the model, and therefore do not calculate:
