ShapeDiver Save Slider Presets
Hi, is there a way in @shapediver to create sliders that automatically update based on a selected preset? For example, if a user selects “Type 1,” the associated sliders reset to predefined optimal values (which the user then can still adjust manually if needed). Similarly, selecting “Type 2” would load a different set of preset values.
The goal is to avoid displaying a separate set of sliders in the final application for each type. I haven’t found a method that works in ShapeDiver. Any suggestions?
Thanks!
We will soon add a way to define presets in Grasshopper and associate them with buttons in the App layout. If you are using the Saved States feature, this will be another option to include a series of presets in the user interface and let users switch between them.
I will update this topic once we make progress about this feature.
