Hi Folks, Is there an object in grasshopper that lets you save your number slider settings into a ‘preset’ that you could load later?
For instance, if I had five sliders set to values: 1, 2, 3, 4, 5 - is there a way to save those values, so that after I change the sliders to 3, 5, 8, 3, 1 I can click a button to return them to 1, 2, 3, 4, 5?
thanks for the help!
You can save the state of a definition with Solution » Save State option from the upper menu bar. It allows you to save the current combination of parameters so you can restore previous settings and alternate between different setups with out having to remember specifics. This is very useful when showing various design alternatives. (Source)
Awesome, thank you! That’s just what I was looking for
You can use this plugin to save , delete , restore states
