Shapdiver app builder specific template
I wanted to check whether it’s possible to create a portrait-specific template in the ShapeDiver App Builder. Currently, I only see landscape layout options available. Since the majority of our users access the app via mobile devices, having a portrait-oriented interface would significantly improve usability and the overall user experience.
Is there a way to enable or customize this layout option? We’d appreciate any guidance or upcoming feature updates related to this.
Thank you in advance!
A quick reply for now: The default page template is responsive and works as you requested, with a slight difference: In mobile mode the right container will be shown below the viewer. The left and the bottom container can be shown using a burger menu. You can give this a try by opening any App Builder example app and resizing the browser window.
Thank you!
Hi @snabela,
Do we have any custom solution, how we can do that? maybe changing in Iframe?
Thank you!
Can you explain what you want to achieve exactly? As Alex mentioned above, the default App Builder template is responsive, which means it will work on a mobile like you described in your post: with the viewer on top, and the right container under it. The left container is hidden behind a burger menu, which can open as an overlay.
Is there something specific that is missing for your application?
Hi @mathieu1 ,
I followed the previous message and working as we need, but will it be possible to change templet size from our side?
