Rhino 8, V-ray 6.
I’m using the viewport to make quick turntable screengrab videos for impatient clients.
I have two problems.
It looks like pillars have sunken down in the ground. The problem can also be seen in the ceiling.
I’ve been poking around with the shadows in the Display mode settings.
This example is done by everything at its max setting. Not suitable for screengrab speed, but the result is not good anyway. I tried to put an object very far below to trick the shadows, but then it just got very bright below the ceiling.
Halos around objects. As can be seen on the right of the sphere on the pillar.
It looks weird when running the turntable as the “glowy” halo follows some objects/backgrounds.
Hi.
It’s a modified version of the Rendered display mode. See the screenshot of the settings below.
Not the raytraced interactive display (real rendering). My graphics card is too slow for making videos in that display mode.
V-Ray has nothing to do with the graphics shown in this mode. V-Ray only supplies the textures. The lighting is entirely Rhino’s OpenGL or DirectX graphics pipeline.
With regard to skylight shadows in Rendered mode. I filed this request a long time ago https://mcneel.myjetbrains.com/youtrack/issue/RH-30310 for a distance slider that I think would help in cases like this. Without that ability, I would use a reduced shadow intensity in Rendered mode as well as a lowered Skylight intensity while using the Sun or another light source for directional shadows.
Thanks Jarek!
Thats very useful!
Quite an improvement, I would say.
Some more tweaking and testing could be done, but just a fast test. Excellent!
I would say that you solved the problem.
It would be great but if you look at it its highly unpredictable as it depends both on camera lens and also target distance… That’s probably why it stays as a test command so far.
But I can imagine this: have sliders for radius (0-10) and intensity (0-10) exposed in UI.
Also please have these settings remembered in the document. @DavidEranen@jeff
Yeah, it really depends on each file and specific camera. And I forgot, only the intensity is limited 0-10, radius can be anything, so not very slider-friendly, it would need to be a value box with arrows in UI : )
I am glad it worked out for you though as-is with the test command.
