[Feature request] Arctic "occlude behind object" setting/slider
My understanding is that in Rhino the Screen-Space AO uses some ZBuffer-driven trickery and not what the “Dirt” material in rendering engine does. It probably comes with some limitations so it may be hard to expect for it to be perfect (but always worth trying!). It has already improved a lot since its introduction in earlier Rhino versions and works very well both in Artic or as a Skylight Shadow in other display modes.
One thing to note is that somehow in Rhino the “radius” of the AO is related to the lens length, so for wide angle lenses the radius gets smaller and vice versa. The camera target distance also affects it so sometimes it is a bit unpredictable how much of the AO effect we get in the viewport.
There is a little known test command that allows us to control the radius and AO intensity in Rhino, that are otherwise not exposed anywhere in Rhino UI (so far only, hopefully).
Check out testssaooptions and its RadiusMultiplier and Intensity settings.
I wrote a little tool for a bit more intuitive control of the AO radius via that command, here is the script:
DIG_SSAO_TuneUp.rvb (3.2 KB)
One thing to keep in mind is these settings don’t “stick” between Rhino sessions so even if you set a view with well adjusted AO parameters, the next time you open the file they will be back to default.
That’s what the script option ReadDocSettings is for - it remembers the last used settings in the file so you can restore them from the next session.
And a sample video showing the lens-AO dependency and how the script works.
hth,
–jarek
