SetUserText is not in the undo stack - will this be added in V6
Does SetObjectText get added to the undo stack ?
Keith
Keith
There are lots of ways to “SetUserText.” How are you doing this?
Sorry to revive an old thread but I was just about to post something with the same title
This can be demonstrated by running the following scripts:
Script A:
rs.AddLine([0,0,0],[0,100,0])
rs.SetDocumentUserText("TEST","True")
Script B:
rs.AddSphere([0,0,0],10)
print str(rs.GetDocumentUserText("TEST"))
If you run script A then B, the document user text is returned (as expected). If you then undo both scripts (Ctrl + z) (both the sphere and line should be gone), then run script B, it will still return true.
Is there another way to use this feature that would add it to the undo stack?
