I would like to set the red arrow as project north:
What is the correct way to do this with a Rhino-created toposolidso that the scope boxes appear in their default/home position, in alignment with the project north?
When I use the rotate project north tool, the scope boxes also rotate:
It also causes some pretty weird behavior with the toposolid. (I got here with “Rotate project north” > select red line > rotate project north 90 degrees CW. )
and now my true north is wrong too:
