def Main():
obj = rs.GetObject('get block')
if not obj: return
if not rs.IsBlockInstance(obj): return
# get block name of the instance
block_name = rs.BlockInstanceName(obj)
# get objects from this block definition
block_objects = rs.BlockObjects(block_name)
block_layers = [rs.ObjectLayer(block_obj) for block_obj in block_objects]
print block_layers
# purge duplicates
block_layers = list(set(block_layers))
#get the instance name
instance_name = rs.ObjectName(obj)
if not instance_name : return
for layer in block_layers:
block_layer_basename = layer.split('::')[-1]
print block_layer_basename
if instance_name == block_layer_basename:
rs.LayerVisible(layer,visible=True)
else:
rs.LayerVisible(layer,visible=False)
Main()
