Setpt & copy upgrades
  1. It would be more convenient if the Setpt window also included the copy option instead of having it on the command line.
  2. The copy command should remember the last distance something was copied, similar to the move command
Hi Dan -
RH-66114 Copy: Rember last used distance
I am less sure that the SetPt request would useful, at the moment - commands use the command line across the board for this as far as I know…
Just add a “checkbox Copy” to the setpt window.
Hi Dan - the question is not what to do, it’s whether it’s a good idea… Currently copy is pretty much universally controlled via the command line… I would hesitate to mess with this.
