I’m a beginner with both programmes and don’t quite understand some of the connections and hope someone can help me and thank you in advance for your help!
I have a problem with the height setting in the Grasshopper file (see screenshot). There should be three levels of 4 mm height. According to Grasshopper it is the 4 mm height, but Rhinoceros only shows me 1 mm.
Is this just a display error or have I set something wrong?
In Rhinoceros I have also tried to connect these three layers together, but without being able to connect the extrusion. How can I do this? It doesn’t work with Boolean union and the Connect function.
Also as @Quan_Li suggested, set your definition to reasonable values before you upload it so it does not take 20 minutes to solve. Also eliminate the use of plug-ins as much as possible. Following these suggestions greatly increases your chances of getting help here (read the entire post linked by @Quan_Li ).
