SelLast lags behind
  1. SelLast often works on the second try.
  2. When I bake two separate components in grasshopper _SelLast recognizes them as one and selects both.
  3. I would consider enhancing SelLast command to work with selection filters.
Hello - can you reproduce this in plain Rhino with no plug-in?
Hello Pascal,
Well, It seems that I can’t.
I am using Elefront plugin to bake (Bake Object component) and it looks that it is because of the plugin.
However, my last point is still actual, maybe some on/off toggle option inside command to switch between ignoring/using filters.
Is Elefront maker active on this forum? What is his/her name?
Hello - the elefront support email is elefront@frontinc.com
I do not know if they have any one looking at this forum, or, more likely, GH or Developer.
