Hey, I´m new to shapediver: I would like to know if it is possible to select a surface within shapediver? I want to select one side e.g. of a cube and apply calculations to this (selected) surface. Thanks!
This is possible at the moment only using the viewer API, which lets you define objects in the scene as selectable and/or draggable. You can read more about this feature here: Interactions - Part 1
Thanks Mathieu, I´ve read the interaction tutorials…Is it possible for the grasshopper definition to “fetch” back the selected surface(s) and apply operations to it? Like e.g. calculating the surface area of the selected surface? Thanks!
