Hi, Any idea of how I can select the points that are inside a bounding rectangle that I draw in Rhino? the points are the vertices of a polyline that I have in Grasshopper and I need to have them in order, thank you very much.
You could try this:
Mainly using the Point In Curve component. It outputs 0 for outside, 1 for on the border of the rectangle and 2 for inside. To be safe, it’s best practice to project the rectangle and the points on the XY plane, to make sure they’re in the same plane.
Cheers
Arie
This did it perfectly, thanks!
