A few days ago I opened the discussion Surface Closest Point, multiple surfaces and it was quickly solved. Today I have a very similar problem. The only difference is the type of curves and surfaces: they are NON-planar.
So the problem is the following: I’ve a non-planar surface and multiple offset curves. I have to select only the curves inside the surface. But, when I use surface closest point component, it isn’t able to recognise the curves inside the surface (from the panel no curve is equal to 0, image below).
I tried with the points inside curves component too, but I had a similar problem.
I used a pufferfish component because allows me to have both sides of the offset (inner and outer curves). I don’t know if there’s another solution to avoid a plugin.
Anyway here is the file with the internalised curves (even if you can still see the offset component)
I’ll try to apply it in more complex geometry to check if still work (in this topic I simplified my original problem), but seems like a very good solution!
