Hi, the issue is like this I have a function that has as input a ObjRef array an inside this function I would like to update the selection by removing or adding other objects to the array, my function is working fine with Curves but if I will create some objects using extrude and I will use those there will be a strange behavior, First thing is that my pre selected objects can only be deselected only after I first select them again, even if those are already highlighted as selected, can not use multiple selection to deselect also. And another strange thing is that if I will select an object(ex: a cube) by a face and I will try to deselect it by clicking on another face it will not work, I need to deselect using same selection face. I will also pot my function code below so, from what I read there are some issues with extruded objects but can anybody suggest a workaround to solve this. Thanks.
public void SelecRhinoObjects(ref Rhino.DocObjects.ObjRef[] objRefs)
Objects.UnselectAll();
if (objRefs != null)
Objects.Select(objRefs);
RhinoDoc.Views.Redraw();
GetObject go = new GetObject();
go.SetCommandPrompt("Select objects");
go.GeometryFilter = ObjectType.AnyObject;
go.GroupSelect = true;
go.SubObjectSelect = false;
go.EnableClearObjectsOnEntry(false);
go.EnableUnselectObjectsOnExit(false);
go.DeselectAllBeforePostSelect = false;
bool bHavePreselectedObjects = false;
for (;;)
Rhino.Input.GetResult res = go.GetMultiple(1, 0);
if (go.ObjectsWerePreselected)
bHavePreselectedObjects = true;
go.EnablePreSelect(false, true);
go.AlreadySelectedObjectSelect = true;
continue;
break;
if (bHavePreselectedObjects)
for (int i = 0; i < go.ObjectCount; i++)
Rhino.DocObjects.RhinoObject rhinoObject = go.Object(i).Object();
if (null != rhinoObject)
rhinoObject.Select(false);
Util.Redraw();
if (go.Objects() != null && go.Objects().Any())
objRefs = go.Objects();
else
objRefs = null;
