Select items
Hello, I have a long list and I want to choose items larger than a specific number and extract them to a new list. also, I want to remove branches from num 0 to 6 for every 23 branches repeatedly. How can I do this?
Internalise numbers and post the file.
Here you are @Piotr
Actually, I want to select items between a range (300to2000).
thank you
Test.gh (13.5 KB)
Hi
I’m not sure what you’re asking for.
You have 969 branches,9 item each. There is no 300-2000 item range unless I flatten the whole list.
Do you need items 300-2000 from the flattened list?
Perhaps something like this?
The A output of Dispatch and the output of Cull Pattern are the same.
Empty branches can be removed with the Clean Tree component if desired.
-Kevin
You got it first… The question was about values 300-2000 :-).
Clear message matters.
The second part of your question.
I’m interpreting this as meaning that you want to eliminate the first 6 hours of each day from some sort of hourly data.
Something like this:
cull_branches_211226a.gh (16.2 KB)
-Kevin
I think Ladybug have a component to choose period?
Test.gh (21.7 KB)
