Select and view Geometry of revit Elements
I want to select Revit elements and view their geometry.
Jazzsharma,
Here is the ever evolving Guide to RiR to get you started. Rhino.Inside®.Revit
To physically select and ‘view’ geometry you can use the Element Geometry component. Depending on what type of Element and how you are trying to view the geometry will drive your next step.
Here is how to extract specific geometry to Rhino as Breps.
https://www.rhino3d.com/inside/revit/beta/guides/revit-elements#extracting-instance-geometry
I want to select all the walls in revit
There is no model category picker in new rhino
You can right-click on the Category Filter and select walls.
You can combine this with Query Elements and Element Geometry.
Query element is only selecting 100 elements.
You can increase the limit, or zoom in on the component and click the minus icon to remove the limit. :slight_smile:
