SectionTools Rhino7 issues
I run Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03001) and latest update of SectionTools
Whilest playing around with the updated SectionTools, Rhino closes down at somehow random instances; once after running _stMake2d several times in a row and once after I used _stDeleteSections.
Got no crash report or option to restore after restarting, it just opens the last saved file.
Anyone else having similar issues?
That is very strange indeed. It only happened to you were using SectionTools and after installing it?
Another question, do you recall doing anything between stMake2D calls, like deleting layers, renaming then, delete objects, changing some properties? I’m trying to figure out the steps where I can repeat at my end to be able to pin point the issue.
Thanks for your help.
Thanks for replying. I tried to recreate the issue but not with succes so far, which is good also.
The only thing i noticed during _stMake2d is my processor usage jumps from 15 to 100% for 2-3 seconds during this make2d process, but not sure if thats odd or not. (intel core i7 6700)
If I bump into this problem again I’ll let you know :slight_smile:
Thanks. I’ll appreciate it.
If you run the Rhino Make2D command, do you also get a usage jump? ST calls the same compute SDK function that Make2D calls and it can be calculation intensive.
Yes, same jump indeed for rhino make2d. At that second peak Rhino actually crashed the same way i mentioned earlier. I think it might have to do something with my model (complex or bad surfaces?) icw this make2D. not a sectiontools bug i guess.
If you can get a repeatable crash with Make2D, then this will be great example to try and fix.
No matter how complex your model is (or even if it has bad objects), Rhino should not crash and we will be very interested to repeat at our end and fix.
Thank you for your time helping spot this one.
I am also having random crashes,Rhino just crashes to desktop or sometimes it hangs and i have to end the task
This happens seemingly randomly.
When creating sections
Editing sections
i assumed it may be bad objects but none show up.
if i reload the file after a crash i can run the same command that crashed it and it’s fine
is there a log file anywhere?
Nosaj,
Can you type in SystemInfo into the Rhino command line and post your results here? Thanks
It’s now randomly crashing when i am placing the section via edit2dLayout section menu
Rhino 7 SR19 2022-6-14 (Rhino 7, 7.19.22165.13001, Git hash:master @ 303aecd3f1907d87fe49f88f695c02fb790b1e31)
License type: Commercial, build 2022-06-14
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro T2000 (NVidia) Memory: 4GB, Driver date: 6-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.59
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.19.22165.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.19.22165.13001
C:\Users\new Jason\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\new Jason\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Hello- thanks- I’ll test - is this repeatable with any geometry? If you have a file that relaiably shows the problem, please post it or send to tech@mcneel.com, with a link back to this topic in your comments.
@rajaa , fyi…
It seems very random.
If i reload the drawng after the crash and do the same section again it generally works
I did a bios update and it seems to be working well now.
