Scripting - rhinocommon join surfaces
I found a Brep.JoinBreps There is also a Curve.JoinCurves. But I need Surface.JoinSurfaces, or if that isn’t possible I need a way to convert surfaces to Breps. Why is there seemingly no way to join surfaces in rhinocommon?
Hello - ToBrep() should do it: https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Surface_ToBrep.htm
I’m also very curious as to why the conversion is necessary. What makes surfaces unjoinable?
Surfaces do not have all the same information as breps - a face list, etc. Joining needs all that stuff for its book keeping. On the other hand surfaces have U and V directions and control points and all sorts of stuff not directly represented in the brep.
So when in the GUI users “join surfaces”, rhino secretly converts the surfaces to breps, joins them, then converts them back?
Yeah in Rhino there is no distinction - a single surface is always still part of a brep, with one face.
Thanks!
