I know the GUI version supports blending from a curve to a point with the _BlendCrv command. RhinoCommon only seems to support the _Blend command. The best I can do with rhinocommon is create a dummy line starting from the point I’m interested in, then blending to that line with continuity1=0. Finally I also have to remove the dummy line. Am I missing a more direct approach? Or is this workaround the best I can do?
What I want:
The only thing I can do:
