I’m getting errors whenever I run the Script Editor and related c# components from within Rhino.Inside Revit with Rhino 8. Script Editor works just fine if I run Rhino 8 by itself.
If I launch the Script Editor from Rhino within the Revit context it will load in Revit 2023-2024, but will start to load but doesn’t open in 2025. Likewise, in Grasshopper, the script components while in the Revit 2025 context will not allow me to open the editor via double-click or from the right-click menu. Revit 2023-24 will open the editor in either GH or Rhino, but I can only use Python.
If I place a new C# script on the GH canvas (Revit 2025) it has an error and warning immediately.
- Error: Language ..csharp@. is not registered.
- Warning: No script to execute. Choose a language from component menu.
The Python 3 and Iron Python versions of the script editor do not show any errors, and they’ll output their default message, but I cannot edit the code within since the editor will not launch.
When I try to run c# code from within Revit 2023 or 2024, I get this:
Error building script: Method not found: ‘Void Microsoft.CodeAnalysis.Emit.EmitOptions..ctor(Boolean, Microsoft.CodeAnalysis.Emit.DebugInformationFormat, System.String, System.String, Int32, UInt64, Boolean, Microsoft.CodeAnalysis.SubsystemVersion, System.String, Boolean, Boolean, System.Collections.Immutable.ImmutableArray
1<Microsoft.CodeAnalysis.Emit.InstrumentationKind>, System.Nullable1<System.Security.Cryptography.HashAlgorithmName>, System.Text.Encoding, System.Text.Encoding)’.
The log looks like this:
Info 5/19/2025 1:19:01 PM [RhinoCode] Storage Site Registered: Local Drive (mcneel.eto.file)
Info 5/19/2025 1:19:01 PM [RhinoCode] Storage Site Registered: Rhino Files (mcneel.rhinoFiles.file)
Info 5/19/2025 1:19:01 PM [RhinoCode] Storage Site Registered: Web (mcneel.console.http)
Info 5/19/2025 1:19:01 PM [RhinoCode] Rhino3D Initialized on Windows - NETCoreApp
Info 5/19/2025 1:19:01 PM [RhinoCode] Platform Registered: Rhinoceros 3D @ 8.19.25132.1001 (mcneel.rhino3d.rhino)
Info 5/19/2025 1:19:01 PM [RhinoCode] Storage Site Registered: Rhino3D Project (mcneel.rhino3d.project)
Info 5/19/2025 1:19:01 PM [RhinoCode] Operating System: Microsoft Windows NT 10.0.26100.0
Info 5/19/2025 1:19:01 PM [RhinoCode] RhinoCode server starting on \\.\pipe\rhinocode_remotepipe_29968
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Registered: Plain Text 1.0 (rhinocode.builtin.text)
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Registered: JSON 1.0 (rhinocode.builtin.json)
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Registered: Yaml 1.0 (rhinocode.builtin.yaml)
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Registered: Git DotFile 1.0 (rhinocode.builtin.gitDotFile)
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Loader Registered: mcneel.pythonnet.python@3.*
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Loader Registered: mcneel.ironpython.python@2.*
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Loader Registered: mcneel.roslyn.csharp@9.*
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Loader Registered: mcneel.gh1.grasshopper@1.*
Info 5/19/2025 1:19:01 PM [RhinoCode] Language Loader Registered: mcneel.markdig.markdown@0.*
Info 5/19/2025 1:19:01 PM [RhinoCode] Using existing runtime: CPython 3.9.10/43 (x64)
Info 5/19/2025 1:19:01 PM [RhinoCode] Initializing CPython 3.9.10/43 runtime
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying python packages
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "site-interop.zip"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "utils.zip"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "pylint-2.10.2-py3-none-any.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "pyflakes-2.4.0-py2.py3-none-any.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "pycodestyle-2.8.0-py2.py3-none-any.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "jedi-0.19.2-py2.py3-none-any.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "black-21.8b0-py3-none-any.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "certifi-2024.8.30-py3-none-any.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "pywin32-302-cp39-cp39-win_amd64.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Deploying package from "psutil-5.9.1-cp39-cp39-win_amd64.whl"
Info 5/19/2025 1:19:01 PM [RhinoCode] Saving CPython runtime configs
Info 5/19/2025 1:19:01 PM [RhinoCode] PYTHONHOME: \\?\C:\Users\tlogan\.rhinocode\py39-rh8
Info 5/19/2025 1:19:01 PM [RhinoCode] PYTHONPATH:
Info 5/19/2025 1:19:01 PM [RhinoCode] Loading CPython engine from C:\Users\tlogan\.rhinocode\py39-rh8\McNeel.Python39.Runtime.dll
Info 5/19/2025 1:19:04 PM [RhinoCode] Preparing SSL context
Info 5/19/2025 1:19:04 PM [RhinoCode] Adding search path C:\Users\tlogan\.rhinocode\py39-rh8\lib\site-packages (from C:\Users\tlogan\.rhinocode\py39-rh8\lib\site-packages\distutils-precedence.pth)
Info 5/19/2025 1:19:04 PM [RhinoCode] Adding search path C:\Users\tlogan\.rhinocode\py39-rh8\site-support\win32 (from C:\Users\tlogan\.rhinocode\py39-rh8\site-support\pywin32.pth)
Info 5/19/2025 1:19:04 PM [RhinoCode] Adding search path C:\Users\tlogan\.rhinocode\py39-rh8\site-support\win32\lib (from C:\Users\tlogan\.rhinocode\py39-rh8\site-support\pywin32.pth)
Info 5/19/2025 1:19:04 PM [RhinoCode] Adding search path C:\Users\tlogan\.rhinocode\py39-rh8\site-support\Pythonwin (from C:\Users\tlogan\.rhinocode\py39-rh8\site-support\pywin32.pth)
Info 5/19/2025 1:19:04 PM [RhinoCode] Adding search path C:\Users\tlogan\.rhinocode\py39-rh8\site-support (from C:\Users\tlogan\.rhinocode\py39-rh8\site-support\pywin32.pth)
Info 5/19/2025 1:19:04 PM [RhinoCode] Running process: C:\Users\tlogan\.rhinocode\py39-rh8\python.exe -I -m pip --isolated --disable-pip-version-check list --path "C:\Users\tlogan\.rhinocode\py39-rh8\site-envs\default-qPH_XJ55" --format freeze
Info 5/19/2025 1:19:04 PM [RhinoCode] Running process: C:\Users\tlogan\.rhinocode\py39-rh8\python.exe -I -m pip --isolated --disable-pip-version-check list --format freeze
Info 5/19/2025 1:19:04 PM [RhinoCode] Running process: C:\Users\tlogan\.rhinocode\py39-rh8\python.exe -I -m pip --isolated --disable-pip-version-check list --path "C:\Users\tlogan\.rhinocode\py39-rh8\site-support" --format freeze
Info 5/19/2025 1:19:04 PM [RhinoCode] Parsing configs schema "https://files.mcneel.com/schemas/rhinocode/editor.schema.v1.json" in C:\Users\tlogan\.rhinocode\editor.json
Info 5/19/2025 1:19:04 PM [RhinoCode] Setting cpython locale to C
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for platform "Rhinoceros 3D @ 8.19.25132.1001 (mcneel.rhino3d.rhino)" references
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for RhinoCodePlatform.Rhino3D, Version=8.19.25132.1001
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Threading.Tasks.Parallel, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Drawing.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Drawing.Common, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Windows.Forms, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for Eto, Version=2.9.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for RhinoCommon, Version=8.19.25132.1001
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for Rhino.UI, Version=8.19.25132.1001
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for Grasshopper, Version=8.19.25132.1001
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for GH_IO, Version=8.19.25132.1001
Info 5/19/2025 1:19:04 PM [RhinoCode] Added Python 3.9.10 (mcneel.pythonnet.python) search path: C:\Users\tlogan\AppData\Roaming\McNeel\Rhinoceros\8.0\scripts
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Private.CoreLib, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Runtime, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Runtime.InteropServices, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Runtime.CompilerServices.VisualC, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Runtime.Extensions, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.ObjectModel, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Collections.NonGeneric, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Threading, Version=8.0.0.0
Error 5/19/2025 1:19:04 PM [RhinoCode] Error calling OnRuntimeReady | Rhino.Runtime.Code.Execution.ExecuteException: Error occured during parsing exception
---> Microsoft.CSharp.RuntimeBinder.RuntimeBinderException: The type 'Rhino.Runtime.Code.Text.TextPosition' has no constructors defined
at CallSite.Target(Closure, CallSite, Type, Object)
at System.Dynamic.UpdateDelegates.UpdateAndExecute2[T0,T1,TRet](CallSite site, T0 arg0, T1 arg1)
at Rhino.Runtime.Code.Languages.PythonNet.CPythonCode.ParseException(RunContext context, Exception exception)
at Rhino.Runtime.Code.Code.Throw(RunContext context, Exception exception)
--- End of inner exception stack trace ---
at Rhino.Runtime.Code.Code.Run(RunContext context)
at RhinoCodePlatform.Rhino3D.Languages.Python3.McNeelPython.OnRuntimeReady()
at Rhino.Runtime.Code.Languages.PythonNet.CPython`1.Start()
Info 5/19/2025 1:19:04 PM [RhinoCode] Language Registered: Python 3.9.10 (mcneel.pythonnet.python)
Info 5/19/2025 1:19:04 PM [RhinoCode] Using existing runtime: IronPython 2.7.12/3 (x64)
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.IO.FileSystem, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Runtime.InteropServices.RuntimeInformation, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Loading IronPython 2.7.12/3 runtime
Info 5/19/2025 1:19:04 PM [RhinoCode] Setting ironpython locale to C
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Collections, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Text.RegularExpressions, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Threading.Thread, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Diagnostics.Process, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.ComponentModel.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Linq, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Threading.Tasks, Version=8.0.0.0
Warn 5/19/2025 1:19:04 PM [RhinoCode] updated ironpython locale to 'C'
Info 5/19/2025 1:19:04 PM [RhinoCode] Added IronPython 2.7.12 (mcneel.ironpython.python) search path: C:\Users\tlogan\AppData\Roaming\McNeel\Rhinoceros\8.0\scripts
Info 5/19/2025 1:19:04 PM [RhinoCode] Language Registered: IronPython 2.7.12 (mcneel.ironpython.python)
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Xaml, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for Microsoft.Win32.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.Diagnostics.Debug, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Building stubs for System.ComponentModel, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.ComponentModel.TypeConverter, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Collections.Specialized, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for Microsoft.Win32.Registry, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Private.Uri, Version=8.0.0.0
Info 5/19/2025 1:19:04 PM [RhinoCode] Stubs already exist for System.Configuration.ConfigurationManager, Version=8.0.0.0
Error 5/19/2025 1:19:05 PM [RhinoCode] Error invoking loader mcneel.roslyn.csharp@9.* | System.IO.FileLoadException: Could not load file or assembly 'Microsoft.CodeAnalysis.CSharp, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. Could not find or load a specific file. (0x80131621)
File name: 'Microsoft.CodeAnalysis.CSharp, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
---> System.IO.FileLoadException: Could not load file or assembly 'Microsoft.CodeAnalysis.CSharp, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.
at System.Runtime.Loader.AssemblyLoadContext.<LoadFromPath>g____PInvoke|5_0(IntPtr __ptrNativeAssemblyBinder_native, UInt16* __ilPath_native, UInt16* __niPath_native, ObjectHandleOnStack __retAssembly_native)
at System.Runtime.Loader.AssemblyLoadContext.LoadFromAssemblyPath(String assemblyPath)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at System.Reflection.Assembly.LoadFromResolveHandler(Object sender, ResolveEventArgs args)
at System.Runtime.Loader.AssemblyLoadContext.InvokeResolveEvent(ResolveEventHandler eventHandler, RuntimeAssembly assembly, String name)
at RhinoCodePlatform.Rhino3D.RoslynLoader.StartCSharpLanguage()
at Rhino.Runtime.Code.Languages.LanguageRegistry.TryInvokeLoader(LanguageSpec spec, AwaitingLanguage awaiting, ILanguage& language)
Info 5/19/2025 1:19:05 PM [RhinoCode] Language Registered: Grasshopper 1.0 (mcneel.gh1.grasshopper)
Info 5/19/2025 1:19:05 PM [RhinoCode] Language Registered: Markdown 0.30.4 (mcneel.markdig.markdown)
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Memory, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Xml.ReaderWriter, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Private.Xml, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.WebClient, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.Requests, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.WebHeaderCollection, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Text.Encoding.Extensions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Collections.Concurrent, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Diagnostics.TraceSource, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.Packaging, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Threading.ThreadPool, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Windows.Extensions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Loader, Version=8.0.0.0
Error 5/19/2025 1:19:05 PM [RhinoCode] Error opening code editor | System.TypeInitializationException: The type initializer for 'RhinoCodeEditor.Editor.RCECommands' threw an exception.
---> System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types.
Could not load file or assembly 'Microsoft.CodeAnalysis, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. Could not find or load a specific file. (0x80131621)
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at System.Reflection.Assembly.GetTypes()
at RhinoCodeEditor.Editor.RCECommands..cctor()
System.IO.FileLoadException: Could not load file or assembly 'Microsoft.CodeAnalysis, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. Could not find or load a specific file. (0x80131621)
File name: 'Microsoft.CodeAnalysis, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
---> System.IO.FileLoadException: Could not load file or assembly 'Microsoft.CodeAnalysis, Version=4.6.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.
at RhinoCodeEditor.Editor.RCECommands..ctor(RCE rce)
at RhinoCodeEditor.Editor.RCE.InitCommands()
at RhinoCodeEditor.Editor.RCE..ctor(Window owner, CodeEditorLaunchOptions options, ILanguageLoadReporter reporter)
at RhinoCodeEditor.CodeEditor..ctor(Window owner, CodeEditorLaunchOptions options, ILanguageLoadReporter reporter)
at RhinoCodePlugin.Commands.ScriptEditorCommand.OpenEditor()
at RhinoCodePlugin.Commands.ScriptEditorCommand.EditScript()
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Windows.Controls.Ribbon, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Drawing.Common, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Drawing.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Windows.Forms, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.IO.Compression, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Windows.Forms.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Win32.SystemEvents, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.ComponentModel.EventBasedAsync, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Diagnostics.StackTrace, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Diagnostics.FileVersionInfo, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Resources.Extensions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Xml.XmlSerializer, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Xaml.Behaviors, Version=1.1.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Serialization.Formatters, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Linq.Expressions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Numerics, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Serialization.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Data.Common, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Reflection.Emit.ILGeneration, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Reflection.Emit.Lightweight, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Reflection.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Xml.XDocument, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Private.Xml.Linq, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.Cryptography, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for Microsoft.Extensions.DependencyInjection.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.ServicePoint, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.Security, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.FileSystem.AccessControl, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.AccessControl, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.Principal.Windows, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Net.Http, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Diagnostics.DiagnosticSource, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Diagnostics.Tracing, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Text.Json, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.Cryptography.X509Certificates, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Reflection.Emit, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Caching, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.ServiceModel.Primitives, Version=6.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.ServiceModel.NetNamedPipe, Version=6.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Serialization.Xml, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Private.DataContractSerialization, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.ServiceModel.NetFramingBase, Version=6.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Reflection.DispatchProxy, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.Cryptography.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.MemoryMappedFiles, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.Pipes, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Threading.Overlapped, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.Claims, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.ObjectPool, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Linq.Queryable, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.FileSystem.Watcher, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Console, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.NetworkInformation, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Intrinsics, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Drawing, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Reflection.Metadata, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Collections.Immutable, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for Microsoft.CSharp, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.DependencyInjection, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.IsolatedStorage, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Text.Encodings.Web, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.WebProxy, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.Sockets, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.NameResolution, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.HttpListener, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Numerics.Vectors, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for mscorlib, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Security.Cryptography.Csp, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Practices.ServiceLocation, Version=1.3.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.DirectoryServices.AccountManagement, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Data, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Xml, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Data.DataSetExtensions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Core, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Win32.TaskScheduler, Version=2.8.16.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Win32.TaskSchedulerEditor, Version=2.5.12.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.ComponentModel.DataAnnotations, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Hosting.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.Kestrel.Core, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.ComponentModel.Annotations, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.Kestrel, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Management, Version=7.0.0.1
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Http.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Hosting, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Configuration.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Configuration, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Hosting.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.FileProviders.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Configuration.EnvironmentVariables, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Primitives, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for Microsoft.Extensions.Logging.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.Kestrel.Transport.Quic, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.Kestrel.Transport.NamedPipes, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.Quic, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.IIS, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.IISIntegration, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Features, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Http, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.FileProviders.Physical, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Configuration.FileExtensions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Options, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Logging, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Diagnostics, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Logging.Configuration, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Options.ConfigurationExtensions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Logging.Console, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Logging.Debug, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Logging.EventSource, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Connections.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Hosting.Server.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.HostFiltering, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.HttpOverrides, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Routing, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Routing.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Mvc, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Mvc.Core, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Diagnostics, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Mvc.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Mvc.ApiExplorer, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Authentication.Core, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for Microsoft.Extensions.Configuration.Json, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Authentication.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Authorization.Policy, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Authorization, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Mvc.Cors, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Cors, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Mvc.DataAnnotations, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IO.Pipelines, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Localization.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Net.Http.Headers, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Http.Features, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.AspNetCore.Metadata, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Net.Http.Formatting, Version=5.2.9.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Runtime.Serialization.Json, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for System.Web.Http, Version=5.2.6.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.DependencyInjection.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.CodeDom, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for Microsoft.CodeAnalysis.CSharp, Version=3.4.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Building stubs for Microsoft.CodeAnalysis, Version=3.4.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Management.Automation, Version=3.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Xml.Linq, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.IdentityModel.Tokens.Jwt, Version=6.5.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.IdentityModel.Tokens, Version=6.5.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.IdentityModel.Logging, Version=6.5.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.IdentityModel.JsonWebTokens, Version=6.5.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for System.Web, Version=4.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Hosting, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Logging.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Diagnostics.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Configuration.CommandLine, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Configuration.Binder, Version=8.0.0.0
Info 5/19/2025 1:19:05 PM [RhinoCode] Stubs already exist for Microsoft.Extensions.Caching.Memory, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Building stubs for Microsoft.Extensions.Caching.Abstractions, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Building stubs for System.Reflection, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Building stubs for System.Globalization, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Threading.Timer, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Text.Encoding.CodePages, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Runtime.Serialization, Version=4.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Numerics, Version=4.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Security, Version=4.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Security.Cryptography.ProtectedData, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Web.HttpUtility, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Building stubs for Microsoft.VisualBasic, Version=10.1.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for Microsoft.VisualBasic.Core, Version=13.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Resources.Writer, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.ComponentModel.Composition, Version=4.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Diagnostics.TextWriterTraceListener, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Diagnostics.Tools, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Transactions.Local, Version=8.0.0.0
Info 5/19/2025 1:19:06 PM [RhinoCode] Stubs already exist for System.Net.WebSockets, Version=8.0.0.0
Would appreciate any help on where to look to fix this. I’ve tried resetting Rhino from within Rhino.Inside, reinstalling Rhino.Inside Revit, deleting the .rhinocode folder in my user directory. So far no luck.
-Tim
