@peter.zock Hi. Would you mind testing this in the latest 8.20 and see if the problems persist? It would also be great if you can give me a set of steps to replicate the problem.
Unfortunately, I already had problems to replicate this problem in the first place. This morning, I have tried the seach field in version 8.19 as well as 8.20. So far, I couldn’t find any problems. I guess you can see this as fixed;
I took a screen recording of the issue.
In some cases like the first try, simply no detection happens and the button is unresponsive.
In other cases there are a few (W:pyflakes) errors.
I’m not sure if this helps, but the issue seems to also be associated (at least in this case) with scripts that have errors and can’t execute, or with scripts where raise Error functions where activated.
Thanks, for some reason I had to restart for Rhino to see the update (tried an update on startup and it said I was up to date). After installing SR21 the issue is indeed fixed, thanks!
