🐛 Script Editor - Always In Foreground Over Rhino 8.19
Hi @eirannejad,
Updated to 8.19 and if the script editor is on top of the rhino window, when the rhino window is given focus, the script editor stays in the foreground still.
-Open Rhino 8.19
-Open ScriptEditor by typing ScriptEditor in CLI and hitting enter
-Place the script editor window over top of the Rhino window
-Click back into Rhino and the script editor will still be in the foreground
Thanks!
System Info
Rhino 8 SR19 2025-4-8 (Rhino 8, 8.19.25098.10001, Git hash:master @ 56a627d5dd9a45a88fe355e5fb333174634cf1e3)
License type: Commercial, build 2025-04-08
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 12-18-2024 (M-D-Y).
> External USB display device with 4 adapter port(s)
- Windows Main Display attached to adapter port 0
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-26-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Redraw scene when viewports are exposed: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.2.1.88
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp “Crash” 1.4.0.0
C:\Users\micha\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.19.25098.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.19.25098.10001
Hmmm. There must have been some Eto changes. Thanks for letting me know. Will look into it
Yeah. There has been some fixes to Eto window ownership which means Script Editor now stays over Rhino window (even when it does not have focus) which is expected since Rhino window is set as its Owner
If this is bothering you I can add an option to turn off this behaviour and make editor window parent-less so it goes behind
If you could please that would be wonderful. It feels far more intutive to me to have whichever window gets clicked on come to the foreground in the event that two or more windows are overlapping. Given that Rhino is the “primary” application interface it feels odd to have it buried behind the SE as much as I love the SE haha.
Also these changes appear to be effecting the code execution where, when exiting out of a script that has eto.form(s) in it, the script editor will stay in the background visually and when i pull it up again it will have the green bar at the bottom as its “executing” still? and will be in readonly mode. To get out of this state I have to click the find/replace spyglass icon and then click it again and then it’s fine again
I’m trying to isolate the issue to capture it consistently but until then leaving that summary here. Had no issues with that this whole time until 8.19.
Thanks for your help!
Sounds good. Here is the YT
RH-87036 Allow editor to hide behind Rhino window
